Embrace your AMD modules
8658
04-29-2015 09:33 AM
ReneRubalcava
Esri Frequent Contributor
7 4 8,658
A question on the forums recently popped up that I thought maybe I could explain better in blog post form rather than a single reply. How do I migrate from legacy Dojo to modern Dojo AMD style? That's a valid question, and one I struggled with when Dojo 1.7 was released. You can refer back to the Migrating to 3.0 in the docs to get an idea of the changes.
I think at this point, people are familiar that dojo.declare is now a module called dojo/_base/declare, but it's how to use AMD bits that causes some confusion.
I think some of the hurdles is just wrapping your head around AMD. I had some brain twisting moments with it at first, as I wasn't sure when to use require or when to use define or how to work with modules. My initial struggles were with requirejs and I had no mentor to really help me out, but I scraped through docs and google groups postings to figure it out, so when Dojo 1.7 was released with the AMD loader, I was better prepared.
Let's break it down to it's simplest form and what you will see in most examples on the ArcGIS Developers site.
require(["esri/map", "dojo/domReady!"], function(Map) {
  var map = new Map("map", {
    center: [-118, 34.5],
    zoom: 8,
    basemap: "topo"
There is the dreaded require method. If you have ever worked in C++/Java or similar languages you may be familiar with the main() function. This is the function that occurs when an application starts up, it's where the party gets started. The require method is the main function of AMD. So somewhere in the ArcGIS API for JavaScript modules downloaded via CDN when you add the script tag to your page is a JavaScript file called map.js in a folder called esri that looks like this.
define(['dependency1', 'dependency2'], function(dependency1, dependency2) {
  var Map;
  /*magic unicorn stuff*/
  return Map;
The require method will go look for that file and load it asynchronously to your application. When it is done loading, the function in your application is then called, the stuff that defines what a Map is (very existential) is returned from the function. Notice the that this module has it's own dependencies, and in the function they are loaded in the order that they are asked for. THIS IS IMPORTANT. Order matters. These dependencies could functions or objects, or maybe strings. Below is a diagram from my book that may help you out.
In my book, I use a file called run.js that does the require method defining my dojoConfig and a main.js that actually starts doing the work. That just happens to be my style, but it's not the definitive style.
Some people get tripped up by the use of main.js and honestly, I did too at first. A good point of reference is the Advanced Modules tutorial from Dojo. I'll quote the important bit under Configuring the Loader.
  • main (optional, default = main.js😞 used to discover the correct module to load if someone tries to require the package itself. For example, if you were to try to require "dojo", the actual file that would be loaded is "/js/dojo/main.js". Since we’ve overridden this property for the "my" package, if someone required "my", they would actually load "/js/my/app.js".
    If we tried to require "util", which is not a defined package, the loader would try to load "/js/util.js". You should always define all of your packages in the loader configuration.
Here is a sample of what one of my dojoConfigs, my require entry point, may look like.
var pathRX = new RegExp(/\/[^\/]+$/)
  , locationPath = location.pathname.replace(pathRX, '');
require({
  packages: [{
}, ['app']);
In the require method, the first parameter is the dojoConfig object, the second is the ['app'] dependency, this is my entry point. So according to the docs above, by simply asking for 'app', by default it will look for 'app/main.js'.
If all this is still too confusing, you can still just define a global dojoConfig object to configure your packages and do a plain older require to start your application. Something like this.
<body class="nihilo">
  <script>
    var dojoConfig = {
      async: true,
      isDebug: true,
      packages: [
        { name: 'xstyle', location: locationPath + '/bower_components/xstyle' },
        { name: 'mayhem', location: locationPath + '/bower_components/mayhem/dist' },
        { name: 'app', location: locationPath + 'js' }
      tlmSiblingOfDojo: false
  </script>
  <script>require(['app/start'], function() {})</script>
</body>
Hopefully that clears some stuff up a bit.
You could learn a lot of this via the Dojo docs and especially the CDN Modules tutorial. This page covers some Legacy to Modern Dojo bits in depth. Here is a migration guide. Here is a legacy Dojo to AMD converter you can also try. I've never used it, but it could be a good starting point. I doubt it will work 100% with all Esri modules, but it's worth a shot.
I hope that helps out a bit if you are still struggling with migrating Legacy Dojo applications to modern  Dojo. It may take some time to let it all sink in, but it will. For more geodev tips and tricks, check out my blog.
4 Comments
EvelynHernandez
Its useful for beginners trying to learn how to develop in JS. But it will be more useful if u put some simple examples about how to modularize ur apps properly, how to call functions from another js,etc.
TracySchloss
Honored Contributor
I have to agree with Evelyn.  Technically, my code uses AMD.  But it's all still in one big file, because I can't figure out how to separate it out.  Every person who posts about AMD and modules. provides the same few links - to ESRI and to DOJO documentation.  I have read all of these dozens of times, but I just don't get how it applies to my work.  I get the core concepts, but applying it to my existing code is a completely different story.
RavindraSingh
yes, Agree with Tracy.
There has to be a baby crawl steps guide .
TyroneBiggums
I would pull out one thing and try to add it to a stand alone file.
1. Start by creating the dojoConfig file in the example above if you don't have one, and adding a script tag in your huge file to reference it.
2. Change the packages line to just one package, and create a location for it in your base root. Packages could look like this: packages: [ { name: 'whatYouReferenceYourModuleWith', location: locationPath + 'folderNameAtYourRoot', main: 'fileNameInAformentionedFolderName} ]
3. Create said folder and .js file referenced above.
4. In file in step 3, add this code: define(function() { return { lookAtMeNow: function() { return 'oh hi'; } } });
5. In your one huge file, add this somewhere (somewhere that you know the DOM is read ... through jquery, dojo, whatever): require(['whatYouReferenceYourModuleWith'], function (whatYouReferenceYourModuleWith) { alert(whatYouReferenceYourModuleWith.lookAtMeNow) } });
In short,
1. Config file makes the modules available
2. Create a package that points to one of your files
3. Create a js file that your config points to
4. define some code for that module
5. require the module defined in step 4 by the name provided in step 2. Note: leaving off the main: 'moduleName' in the package will cause the config to look for main.js (which is what was in the original post).
disclaimer: That's as baby stepped as it can be, pretty much, and I didn't test that actual syntax.
About the Author
Softwhere Developer at Esri working on cool stuff! Author: Introducing ArcGIS API 4 for JavaScript: Turn Awesome Maps into Awesome Apps https://amzn.to/2qwihrV ArcGIS Web Development - https://amzn.to/2EIxTOp Born and raised in East L.A.
