ArcGIS JavaScript with UK data - URL.searchParams
1337
07-06-2020 12:46 PM
Egge-Jan_Pollé
0 0 1,337
EggeJan_Poll_0-1711390386693.pnghttps://community.esri.com/people/EPolle_TensingInternational/blog/2020/03/24/arcgis-javascript-with...
Setting x, y and zoom level in url to retain map view
When you zoom in on a particular location on a map, you sometimes wish you could retain that map view, e.g. to share it with someone else. That's why we were looking for a way to get the x, y and zoom level from the search parameters in our url. But not only do we want to be able to read the values from the query string (i.e. everything behind the question mark), we also want to be able to set them, and to modify them whenever the map view changes, i.e. when the user pans and zooms around on the map.
Below is a description of the functionality we use to grab the x an y coordinates (in British National Grid, rounded to the full meter) and to modify the url.
URLSearchParams and History.replaceState()
The URLSearchParams interface defines utility methods to work with the query string of a URL. In the example below we use the following methods of this interface:
  • The has() method indicates whether a parameter with the specified name exists
  • The get() method returns the (first) value associated to the given search parameter
  • The set() method sets the value associated with a given search parameter. And very important: if the search parameter does not yet exist (which might initially be the case), this method will create the search parameter.
The History.replaceState() method modifies the current history entry. This method is particularly useful when you want to update the URL of the current history entry in response to some user action, e.g. the panning and zooming mentioned before.
And this is how it works:
If you provide the url without any parameters, you will start at the Default map view. But as you will see, the default parameters are added immediately to the address bar:
https://twiav.nl/en/arcgis/javascript/arcgis_javascript_with_uk_data_url_parameters.htm
And as soon as you start zooming and panning around, these parameters will be adjusted every time the view becomes "stationary" (we do use reactiveUtils to check the state of the view, stationary or not),
In this way, you can zoom in to a particular spot and copy the url to make sure to share exactly that map view.
If you click on the link below you will immediately end up in Steòrnabhagh  (or Stornoway in English, we are using the Web Map GB Cartographic Local Names here), on the island of Lewis and Harris in the Outer Hebrides:
https://twiav.nl/en/arcgis/javascript/arcgis_javascript_with_uk_data_url_parameters.htm?x=143956&y=9...
Happy coding!
The code
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>ArcGIS JavaScript with UK data - URL Parameters: x, y and zoomlevel</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.29/esri/css/main.css">
  <script src="https://js.arcgis.com/4.29/"></script>
  <style>
    html, body, #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
      require([
        "esri/Map",
        "esri/geometry/Point",
        "esri/views/MapView",
        "esri/widgets/Home",
        "esri/Viewpoint",
        "esri/core/reactiveUtils"
      ], function(Map, Point, MapView, Home, Viewpoint, reactiveUtils) {
      var sr = 27700;
      var xCoordHome = 500000;
      var yCoordHome = 500000;
      var zoomLevelHome = 5;
      var scaleHome = 4612360;
      var xCoord = xCoordHome;
      var yCoord = yCoordHome;
      var zoomLevel = zoomLevelHome;
      if ('URLSearchParams' in window) { // Feature detection (URLSearchParams is not supported by Internet Explorer)
        var url = new URL(document.URL);
        var search_params = url.searchParams;
        // get searchparams if x, y and l are provided in url
        if(search_params.has('x') && search_params.has('y') && search_params.has('l')) {
          var xCoord = parseInt(search_params.get('x'));
          var yCoord = parseInt(search_params.get('y'));
          var zoomLevel = parseInt(search_params.get('l'));
      var map = new Map({
        basemap: {
          portalItem: {
            // GB Cartographic Local Names, hosted by EsriUKContent, see: https://www.arcgis.com/home/item.html?id=5b9d5ac7e17f402a9111f1ca2c22bf56
      var view = new MapView({
        spatialReference: sr,
        container: "viewDiv",
        map: map,
        center: new Point({x: xCoord, y: yCoord, spatialReference: sr}),
        zoom: zoomLevel
      var home = new Home({
        view: view,
        // viewpoint of home needs to be defined (hard coded) because otherwise this home depends on the x, y and l values in the searchparams
        viewpoint: new Viewpoint({targetGeometry: new Point({x: xCoordHome, y: yCoordHome, spatialReference: sr}), scale: scaleHome})
      view.ui.add(home, "top-left")
      reactiveUtils.when(
        () => view?.stationary === true,
          modifySearchParams();
      //modify url with new coords and zoomlevel as searchparams
      function modifySearchParams() {
          xCoordNew = parseInt(view.center.x);
          yCoordNew = parseInt(view.center.y);
          zoomLevelNew = view.zoom;
          search_params.set('x', xCoordNew);
          search_params.set('y', yCoordNew);
          search_params.set('l', zoomLevelNew);
          url.search = search_params.toString(); // change the search property of the main url
          new_url = url.toString(); // the new url string
          history.replaceState(null, '', new_url);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Contributors
About the Author
GIS Consultant at Avineon-Tensing
