Toolbox format matrix
2510
10-14-2022 04:13 AM
With the release of ArcGIS Pro 3.0, there are three toolbox formats available in ArcGIS. This matrix is an attempt to help you decide which is appropriate for your work.
 atbxtbxpyt
DescriptionArcGIS Pro 3.xArcMap, Pro 1.x, 2.xArcMap 10.x, Pro
FormatXML-basedtext/binarypython code
Model Builder supportYesYesNo (but references to model builder tools supported)
Python skills requiredMinimalMinimalYes
Container (location toolbox is saved)Folder or gdbFolder or gdbFolder
Script tool parameter validationProperty sheets and validation codeProperty sheets and validation codecode
Full read/write support across versionsPro 3.x onlyWithin current version (Pro 2.1, ArcMap 10.8)With careful coding can support all versions (at least in a limited way), even ArcMap and Pro
Read toolbox created with previous versionYesYesYes
Save toolbox to previous version
Yes
(Save to tbx file - not gdb, with optional validation tools)
YesNo
Documentation sourceEmbedded in toolboxEmbedded in toolboxXML files in same folder as pyt file
Efficient with git and other version control systemsNoNoYes (as pyt and associated .py or .xml files are entirely code)
Embedded code encryption supportedYesYesNo
Comments
DuncanHornby
MVP Notable Contributor
Reckon you could add a row to your table indicating level of supporting for source code encryption?
Version history
Last update:
‎12-27-2023 12:23 PM
Updated by:
Contributors
