What does the E stand for in multiversioned _EVW view name?
1928
03-24-2025 07:32 PM
Bud
Legendary Contributor
ArcGIS Pro 2.9.5 Oracle 18c 10.7.1 EGDB; traditional versioning moving edits to base
What does the “E” stand for in the autogenerated view "..._EVW" naming convention?
I have a vague memory that the E stands for “editioned” views. But that might not be right. "Edit"?
JoshuaBixby
MVP Esteemed Contributor
Although George's guess of "enterprise" is reasonable, my money is on "esri," with a very small chance "enhanced."
The earliest mentions of "multiversioned views" that I recall are from ArcGIS 9.2, which coincidentally the ArcGIS 9.2 Desktop Help is still available online (kudos to Esri for keeping the historical record alive online).  From ArcGIS Desktop Help 9.2 - Using multiversioned views:
What are multiversioned views?
Multiversioned views incorporate database views, stored procedures, triggers, and functions to access a specified version of data in a geodatabase table using structured query language (SQL).
In the early days, the documentation suggested using either a "mv_" prefix or "_mv" suffix:
  1. At a command prompt, execute the sdetable function to create a multiversioned view.
sdetable –o create_mv_view –T permits_mv –t permits –i 4400 –D code –u sarja –p not4u
The "mv" prefix or suffix made sense given the name of the feature was "multiversioned view."  However, around that same time "mv" started becoming associated with "materialized views."  As important as geodatabases may be to us GIS users, the non-spatial use of databases dominates the spatial use of databases, so most people in the database world would associate "mv" with "materialized view" and not "multiversioned view."
There was a brief period after transitioning from "mv" where Esri adopted "vw," which is a standard suffix or prefix for any database view.  I believe it was also around this same time that Esri moved away from "multiversioned views" and starting use just "versioned views."  Although "vv" is a logical abbreviation for "versioned view," my guess is people didn't like it because it might be too easy for people to confuse "vv" for "w".
Similar to Esri JSON, Esri JS, and other standard terms that Esri prefixes with their name, my guess is that "e" in "evw" is for Esri.  Also, the change from "SDE" to "Enterprise geodatabase (EGDB)" came many years after the switch to "evw" so I don't think the word "enterprise" was the motivation.
George_Thompson
Esri Notable Contributor
I like edit 😀....... or "enterprise", I honestly have no idea.
I do remember when they started to add the "e" around 10.1/2'ish time frame. Before that it was just a "_vw" which people would also name their custom DB views so it could be confusing on which ones were "versioned" in the enterprise geodatabase.
--- George T.
JoshuaBixby
