SQL View using Multi versioned views not returning all rows
1381
10-01-2024 07:21 AM
Labels (2)
MeleKoneya1
We have a view that uses several multi versioned views to export our parcels.    We are joining a number of attributes from different sources to the parcel shape.
For years, this view was working fine, but now, it is not returning all the shapes for the parcels.
Are there any tips or tricks for performing such a join?
We are using the multiversioned view as we don't have the attributes in the base tables.
SELECT   Addr.OBJECTID,
  Addr.asset_id,
  Addr.parcel_code,
  Addr.insert_date,
  Owner.owners_name,
  Addr.fulladdr,
  Addr.zip_code,
  Addr.qs_num,
  subdiv_name.subdiv_name,
  Addr.mcr_number,
  Addr.lot_number,
  Addr.tract_name,
  Addr.full_zoning,
  Addr.full_fema,
  Addr.char_area,
  Addr.use_code,
  addr.juris_code,
  Owner.owners_deed_number,
  Owner.owners_deed_date,
  Owner.owner_use_code,
  Owner.legal_class,
  Owner.mail_address,
  Owner.mail_city,
  Owner.mail_state,
  Owner.mail_zip,
  Parcels.mslink,
  parcels.sq_ft,
  Parcels.acres,
  Parcels.Shape
  FROM
(SELECT        OBJECTID, parcel_centroid_id, asset_id, apn AS parcel_code, creation_date AS insert_date, site_address AS fulladdr, zip_code, qs_num,
                         mcr_num AS mcr_number, lot_num AS lot_number, tract_name, full_zoning, full_fema, char_area, use_code, jurisdiction AS juris_code
FROM            LMS_SDE.lms.PARCEL_ADDRESS_POINTS_EVW
 WHERE        (use_code NOT IN ('R', 'S')) AND (feature_state = 'ACTIVE')) AS Addr
LEFT OUTER JOIN
    (Select  MSLINK, Shape,  Shape.STArea() AS sq_ft, Shape.STArea() / 43560 AS acres
from lms_sde.lms.Fabric_parcels_polys_evw) AS Parcels ON Addr.parcel_centroid_id = Parcels.MSLINK LEFT OUTER JOIN
                             (SELECT DISTINCT
                              OWNER_NAME AS owners_name, APN, deed_num AS owners_deed_number, DEED_DATE AS owners_deed_date, property_use_code AS owner_use_code, Legal_Class, CASE WHEN mail_addres_2 IS NULL THEN mail_address_1 ELSE mail_address_1 + ' ' + mail_addres_2 END AS mail_address,
                               mail_addres_2, MAIL_CITY, MAIL_STATE, MAIL_ZIP
                               FROM            LMS_SDE.lms.COUNTY_PARCELS) AS Owner ON Addr.parcel_code = Owner.APN LEFT OUTER JOIN
                             (SELECT DISTINCT mcr_num
                               FROM            LMS_SDE.lms.FABRIC_SUBDIVISION_BOUNDARY_POLYS_EVW) AS Subdiv OUTER APPLY
                             (SELECT        TOP 1 name as subdiv_name, last_edit_date
                               WHERE        Subdiv.mcr_num = mcr_num) Subdiv_Name ON Addr.mcr_number = subdiv.mcr_num
George_Thompson
Esri Notable Contributor
Was there any update on the SQL Server machine or the Enterprise Geodatabase before the issue occurred?
--- George T.
MeleKoneya1
George,  the SQL instance was upgraded to 2019.   The combability mode is at 2017.   The Geodatabase is 10.6.1 Geodatabase.    We use ArcMap clients still.   Should we upgrade the Geodatabases?
George_Thompson
Where any of the changes above made before the behavior started?
I have seen something similar when we completed an upgrade of the EGDB from version x --> y. It gave an error when you opened the view in SSMS.
Usually do not see something working one day and the next not working without a patch / update / etc.
--- George T.
