SQL Server st_transform equilavent
6156
09-05-2018 01:32 PM
JeffPace
We have been encourage to migrate from Oracle to SQL server for multiple reasons.  In doing a gap analysis, most of what we do seems pretty transportable.
The one thing we seem to be missing is sde.st_transform.  We keep our data natively in State Plane, but create spatial views to show the data in different coordinate systems, or to add Lat/Long coordinates, or to union datasets in different systems.  This is an absolute necessity to be able to do live.
Is there any solution at all ?
JonathanFarmer_oldaccount
Hi Jeff,
Unfortunately, Microsoft does not allow transformations through their ST functions like we do for Oracle and PostgreSQL DBMS's.
The only workaround that is going to work here is to use 2 spatial columns in the table in SQL Server. While we do not support multiple spatial columns when working with tables or views in ArcGIS, Microsoft does. So you could add a second spatial column in the WKID that you need and then create a view or query layer using only one of those columns for use in ArcGIS. Outside of this though, I can't think of another way around it.
Jonathan
