sde service
4698
05-18-2016 06:01 AM
LuisinaArrúa
HI all:
I'm install arcsde 10 with oracle.
I import shape to the database. Enable the geodatabase and grant permissions to packages, etc etc
NOW...
the service sde is not working, not activated by default in the service esri_sde file.
is that necessary? for what?
how active service ?
Thanks.-
DerekLaw
Esri Esteemed Contributor
Hi Luisina,
FYI, ArcSDE 10 technology (which was included as part of the ArcGIS 10 release) is no longer supported and has been retired since Jan 1st, 2016.
Product Life Cycle doc
http://downloads.esri.com/support/product%20life%20cycle/server_gis/ArcGISServer_PLC.pdf
I recommend that you upgrade to a more recent ArcGIS release.
Hope this helps,
LuisinaArrúa
ArcSDE 10.1 has been retired?
Thanks, anyway let me know the tasks that follow after installing ArcSDE 10.1
DerekLaw
Hi Luisina,
I'm not sure which DBMS platform you are using for your enterprise geodatabase. Please find the appropriate help documentation for ArcSDE 10.1 technology from this page:
Help for Previous Versions | ArcGIS Resources
Look on the right side of this page, under the installation guides section (ArcSDE application server),
Hope this helps,
