Registering with Geodatabase causes table to disappear in other account
2035
5
10-13-2017 06:00 AM
JohnBroecher
I have two accounts for a SQL Server db and two sde connections for that db using the same logins, one is an admin and one is a reader. I create tables in SQL Server using the admin account. They are visible in SQL Server and ArcCatalog using using both the reader and admin accounts. Then after registering the tables in ArcCatalog with the admin account, the tables disappear from the ArcCatalog reader account.
How would I make them visible in the reader account again?
I am using ArcGIS 10.5.
Asrujit_SenGupta
Close ArcCatalog> Reopen> Connect as the Reader and checked again?
Asrujit_SenGupta
JohnBroecher
That was it!
Asrujit_SenGupta
John Great! Please go ahead and close the thread if the issue is resolved and you have no other questions.
JohnBroecher
I don't see that option in the action menu.
Asrujit_SenGupta
No, there is not a separate option as such. Just marking a response as correct Or the question as 'Assume Answered' indicated the OP's questions have been answered.
