Python Script - Updating Feature Class in SDE daily
9328
15
10-01-2015 05:17 PM
timdunlevie
Hi all,
I am going to implement a nightly script which will remove all records in a Feature Class in our spatial DB, and append new records.
Apart from compressing the Database, is there anything else I should manage? Analyze ? Should I remove any locks that could be connected?
This process will run every night.
Will compressing the entire DB have an effect with any child/parent DBs ?
Also, are you able to compress a single Feature Class rather than an entire DB ?
we run 10.2
Tim
RandyKreuziger
Our Corporate Library SDE database has no versioned feature classes so we do the Truncate / Append all the time.  Many of the datasets are coming from other state agencies so it's just easier to do it this way.
MichaelVolz
Esteemed Contributor
How often do you truncate and append your non-versioned feature classes from other state agencies?
JoshuaBixby
MVP Esteemed Contributor
Instead of getting into the specifics of what works for us, and might not work for others, I encourage you to look over An overview of the Data Comparison toolset if you haven't already.  I have used both Feature Compare and Table Compare.  Although they require a bit of setup, once done, the tools can be quite efficient.  The Detect_Feature_Changes tool has always intrigued me, but I have never taken the time to try it out.
MichaelVolz
I agree with Joshua as the DBA of my organization would only do an incremental update of data in an SDE feature class and not a full truncate and append as there is a cost in swap space (or something to that effect) with the truncate and append process.
BarryGuidry
Tim, would you mind posting your script?  I did this in the past, and posted to the ESRI forums, but was removed with the archives I guess.
Thank you,
Barry Guidry
timdunlevie
Hi Barry,
I will have to dig out the code as I have since left the company I implemented this with…
Tim
