PostgreSQL9.4/PostGIS 2.1.7. with AGS 10.3/SDE enterprise multiuser
9682
12
05-20-2015 02:57 AM
SandraToepsch
Greetings,
we intend to set up a new ArcSDE Geodatabase: ArcGIS Server 10.3/SDE enterprise multiuser based on PostgreSQL9.4 with PostGIS 2.1.7.
The ESRI Support stated that AGS 10.3 is tested with PostgreSQL9.3, but should also work with 9.4. So I was wondering whether there are users with practical experiences on this issue? Can you confirm that PostgreSQL9.4/PostGIS 2.1.7. works with AGS 10.3/SDE enterprise multiuser?
Thanks in advance, KR Sandra
HectorCervantes
I also understood the minimum requirement PG9.3.5 to support higher then 9.3.5.  So are there any plans to support PG9.4 even 9.5?
AsrujitSengupta
Hector Cervantes​ Which version of ArcGIS Desktop are you using?
PostgreSQL 9.4.5 is mentioned as supported Database version for Desktop 10.4. However, PostgreSQL 9.5 is still not supported...
PostgreSQL database requirements for ArcGIS 10.4—Help | ArcGIS for Desktop
HectorCervantes
I am using 10.3 and I also have 10.2 clients connecting to the database. Thanks for your reply.
-Hector Cervantes
