PL/SQL Code Review: Set polyline M-values to cumulative length of line
1215
03-30-2022 07:17 AM
Bud
Legendary Contributor
I have a multi-part polyline in an SDE.ST_GEOMETRY feature class (Oracle 18c EGDB).
I've written a PL/SQL function that replaces the geometry's M-values with the cumulative length of the line.
(My plan is to eventually create a database trigger that uses the function to update polyline geometries — when features get edited.)
Input:
MULTILINESTRING M (( 0.0 5.0 -100000.0, 10.0 10.0 -100000.0, 30.0 0.0 -123),( 50.0 10.0 456, 60.0 10.0 789))
--select sde.st_astext(shape) from polylines
Output:
MULTILINESTRING M ((0 5 0, 10 10 11.18, 30 0 33.54),(50 10 33.54, 60 10 43.54))
--select m_as_length(shape) from polylines
Question:
The m_as_length() function works as expected.
But I'm a PL/SQL novice, so I thought I'd ask: Can the script be improved?
with
    function pythagoras(x1 in number, y1 in number, x2 in number, y2 in number) return number is
    begin
      return round(sqrt( (x2 - x1) * (x2 - x1) + (y2 - y1) * (y2 - y1)), 2);  -- Power is a slow function
    end;
    function m_as_length(shape in sde.st_geometry) return varchar2
    is
        result              varchar2(32767);
        vertex_set          varchar2(32767);
        oldX                number;
        oldY                number;
        newX                number;
        newY                number;
        line_len            number := 0;
    begin
        for vPartIndex in 1..sde.st_geometry_operators.st_numgeometries_f(shape)
        loop
            vertex_set      := null;
            for vPointIndex in 1..sde.st_geometry_operators.st_numpoints_f(sde.st_geometry_operators.ST_GeometryN_f(shape,vPartIndex))
            loop
                newX        := sde.st_geometry_operators.st_x_f(sde.st_geometry_operators.st_pointn_f(sde.st_geometry_operators.st_geometryn_f(shape,vPartIndex),vPointIndex));
                newY        := sde.st_geometry_operators.st_y_f(sde.st_geometry_operators.st_pointn_f(sde.st_geometry_operators.st_geometryn_f(shape,vPartIndex),vPointIndex));
                if vPointIndex <> 1 then
                   line_len := line_len + pythagoras(oldX, oldY, newX, newY);
                end if;
                oldX        := newX;
                oldY        := newY;
                vertex_set  := vertex_set || newX || ' ' || newY || ' ' || line_len || ', ';
            end loop;
            result          := result || '(' || rtrim((vertex_set),', ') || '),';
        end loop;
        return 'MULTILINESTRING M (' || rtrim((result),',') || ')';
    end;
select
    m_as_length(shape)
from
    polyline
Related:
  1. Use SDE.ST_GEOMETRY functions in a custom function
    • Explains why the function calls are so verbose:  sde.st_geometry_operators.st_numgeometries_f.
  2. ST_GEOMETRY functions:
  3. I'm aware that this sort of thing can be achieved with Arcade in ArcGIS Pro 2.6+. Even still, I want to learn how to do this in PL/SQL, for professional development reasons, and to have a plan B, for scenarios where Arcade won't work (due to compatibility issues, etc.).
  4. My FC is registered as versioned (with option to move edits to base). We don't use named versions, we only use the default version (so that we can undo/redo edits while editing). So in this case, using database triggers on a versioned FC shouldn't be an issue -- especially since we're exclusively working in the base FC -- and are using the "with base" option.
