ORA-01445: cannot select ROWID from, or sample, a join view without a key-preserved table
5432
12-27-2016 10:08 AM
JoseSanchez
Hello everyone,
When opening a SDE view directly in oracle with Oracle SQL Developer to see the Data we get the following error message:
The SDE view shows correctly in ArcCatalog but now in SQL Developer  we get this error message.
It looks like the error is caused by the field "SHAPE", because removing this field allows to Open the view and see the data.
SELECT FC.SHAPE,
    FC.OBJECTID,
    FC.ProjectID,
    TableView.STATUS,
    TableView.PROJECTNAME,
    TableView.PROJECTLOCATION,
    TableView.PROJECTDESCRIPTION
  FROM APP.FC,
    APP.TableView
  WHERE FC.ProjectID IS NOT NULL
  AND FC.ProjectID    = TableView.ProjectID;
JoshuaBixby
MVP Esteemed Contributor
What version of Oracle?  What version of ArcGIS?  Using ST_Geometry, SDO_Geometry, or compressed binary?  How was the view created, using ArcCatalog, the old SDE command line tools, etc...?
JoseSanchez
The version of Oracle is 11G but we upgraded this week to 12C.
ArcGIS Client 10.2.2
ArcSDE 10.2
Using ST_Geometry
For testing purposes we created the two views with the same code using the old SDE command line, and ArcCatalog View. Both show the same error message.
