Not able to set workspace using standalone Python script for ArcGIS
13448
28
08-21-2018 11:51 PM
HarshalGharat
I am facing a very weird issue in setting the workspace. When I setup the workspace inside python window in ArcMap/ArcCatalog, it just works fine. But the moment I do the same in a standalone python script, the things do not work at all. I tried other options like creating connection file in scratch folder and then setting it as a workspace but still no luck. I am facing this issue on ArcGIS Desktop 10.2.1 and my database is 64 bit Oracle.
I had ArcGIS Pro 2.1 installed on the same machine hence I also tried the same thing after uninstalling ArcGIS Pro but still no luck.
Jose_AlvaroSanchez_Huamani
I had the same problem. This works when you set in PyScripter, menu Run, Python Engine, Internal.
JoeBorgione
I like to use ArcCatolog to provide the the path:  with it open, navigate to the workspace and up at the top of the window is the actual path.  Click, copy and paste it into your code:
arcpy.env.workspace = r'X:\your\copied\path\here'
HarshalGharat
Not working for me
JoeBorgione
I hate it when that happens; thing is, your actual path names have spaces in them, right?  If you take them out in the python script it's not going t find them....
HarshalGharat
I meant, I created a new connection file in a directory where the sde file and directory name didn't have any spaces.
JoeBorgione
Hmmm.  As you stated in your op; this is weird issue.  Not sure what's going on here....
HarshalGharat
I have raised a ticket with Esr tech support on this, will keep you posted
JoeBorgione
That's the route to go at this point.  It's just so very odd...
NikolaCacanoski
I had the same problem, and I solved it with copying the sde file to location where there won't be space character in the path. Also, I have renamed the sde file. Example: C:\sde\myconnection.sde
