Is ArcGIS an RDBMS?
1261
12-04-2019 05:29 PM
by Anonymous User
Not applicable
I am going to use the ArcGIS platform as a data source and visualization platform by using the Operations dashboard. But still, I have a concern that can I use complex queries and get all the questions that I need.
eg: I may need to have a unique field ID and sum of other numeric fields as I do in MS Access.
Ismael ChiviteJames Tedrick
Wali
George_Thompson
Esri Notable Contributor
ArcGIS is not an RDBMS, it can be used to communicate with an RDBMS (SQL Server, Oracle, Postgres, etc.).
You will need to have the data published to ArcGIS Enterprise for the Ops Dashboard.
Understand data sources—Operations Dashboard for ArcGIS | Documentation
--- George T.
