Get geodatabase version (upgrade status) using ArcPy
3672
12-15-2021 05:31 AM
evemarwernick
Is it possible to get geodatabase version (upgrade status) using ArcPy? Like showned in image anexed.
Thanks
Asrujit_SenGupta
That information is normally available in the Version table (DESCRIPTION field) in the database. So you can query that table using SQL or Python and get the geodatabase version.
ArcSDESQLExecute
Example: Finding the geodatabase release using SQL
DanPatterson
MVP Esteemed Contributor
evemarwernick
Hi Dan,
Thank you for your answer, but it is not what I am looking for...
I need to programmatically discover the version of the geodatabase, for example 10.2 - please look the attachment in my post.
Asrujit_SenGupta
ArcSDESQLExecute
evemarwernick
Exactly what i needed!
Thank you!!!
