Feature Class with Identity Column Failed to be Registered as Versioned
2995
09-05-2022 01:28 AM
User35489
Hello There,
I tried to enable traditional versioning on a Feature Class with a column enabled for SQL Server identity property. It failed with the error 999999, Invalid column datatype.
Attached: Error snapshot
Is the below link still valid
https://support.esri.com/en/technical-article/000011579
Software:
ArcGIS Pro 2.9, Enterprise Geodatabase, SQL Server 2019
MarceloMarques
Yes, the article is still valid and correct https://support.esri.com/en/technical-article/000011579
SQL Server Featureclass with a column that has Identity Property set to True is not supported.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
George_Thompson
Esri Notable Contributor
You may have to contact technical support on this one. I did find this: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-sql-server/data-types-sqlserv...
Not sure it answers your question. But it seems it may be something on the OBJECTID field only.
OBJECT ID
int(4) when created in an enterprise geodatabase
integer with identity property when created in a database
The ArcGIS type ObjectID is the registered row ID column for the table (or feature class.) Only one may exist per table.
--- George T.
MarceloMarques
