Exporting and importing SDE versions
2358
03-24-2019 06:15 AM
JoseSanchez
Hello everyone,
Looking for samples to export and import SDE versions between databases with the same schema.
Thanks
Asrujit_SenGupta
Isn't this the same as this question already posted by you: https://community.esri.com/thread/230931-any-tool-to-copy-sde-versions-from-one-database-to-another ?
ConnorFriese
Jose Sanchez
There is not a way to export and import versions between enterprise geodatabases.
Asrujit SenGupta‌ is correct by saying this is the same question he referenced.
I see he has listed a way to export the data from a specific version and it looks like that would work.
However, that would just be exporting the data from a version and you wouldn't exactly be able to import as a version into another enterprise geodatabase.
The data could be appended in some sort of fashion though.
JoseSanchez
Thanks you very much for your answers!!
