Enterprise Replication Issues
1352
09-06-2024 02:40 PM
EdwardBlair
We step up replication from a versioned production Geodatabase into versioned replica about a month ago.  We haven't synchronized for several weeks.   There have been thousands of edits performed in the interval.  When we just recently performed a sync only a handful of features were copied to the replica.  Based on a CREATED_DATE field we can easily see that some classes were not moved at all.
When we set up the replica we had a DBA make a new Oracle instance and load a backup from production, so on creating the replica we simply registered all the classes - and we made sure all classes were registered.
So, the question is, what could make the sync send only a handful of features when we expected many?
Any insights would be much appreciated.
Thx,
Ed
George_Thompson
Esri Notable Contributor
Are all the edits showing in the DEFAULT version or the version that the replica was created off of?
Sounds like some of the edits are not in the version that is being synced.
What version of Pro did you use to configure the replica?
--- George T.
EdwardBlair
George -
Thanks for the feedback.  All edits in the parent were present in the SDE.Default version.    Though I guess I need to triple-check that the replica was created from this version.
We're using ArcMap version 10.6.1.   And yes, I know this is old.
Thx,
Ed
EdwardBlair
I think I found our problem....  we had inadvertently set the option to use geometry when we really did not intend to.  Most feature did not fall in the display extent present when we created the replica.
Will change and confirm.
Ed
