Can't Identify on a spatial view
4801
12
07-08-2019 07:57 AM
MichaelGinzburg
I created a spatial view by joining a layer and a view.
For some reason I cannot Identify features and select them on the map.
However:
I can see the features on the map (e.g. geometry is joined)
I can open attribute table and see the whole data (e.g. it's business data is  joined)
I can correctly zoom to a feature from the attribute table (e.g. geometry is correctly connected to the business data)
I even can get the Identify tool from the attribute table.
But I cannot get it from the map.
What is the problem?
ArcGIS 9.3 SDE on Oracle.
ArcGIS 9.3 Desktop
I know, that there tools are history, but some of my clients insist on continuing to use them....
Thanks in advance!
MichaelGinzburg
I tried to create a simply view, only OBJECTID and Shape fields - still no results.
The Geodatabase is ST_Geometry.
George_Thompson
Esri Notable Contributor
At this point, I would recommend upgrading to a supported version of the Enterprise Geodatabase and then retest. If that does not work, I would connect Esri technical support.
--- George T.
MichaelGinzburg
Hello again,
Thanks to everybody who participated.
I rebuilt the DB server. Now I have no problem with spatial indices. Nor with identify.
I have problem with selection. I can't select from spatial view. Getting no results.
What can be the problem?
Still on 9.3.1.
Thanks!
