ArcSDE Feature class extent is in inconsistent spatial reference system.
4070
8
04-15-2025 08:16 AM
AlisonWieckowicz
A feature class in our enterprise geodatabase seems to have an extent with inconsistent coordinates. See attached image.   It appears that the lower left bounding coordinates are in unprojected/lat long coordinates when the feature class should be stored in 26915 NAD 83 15N.   The upper right coordinates look appropriate.
What could cause this?
VinceAngelo
Esri Esteemed Contributor
Loading incorrectly projected data would certainly cause this, even if it was then deleted.
You should do a search for data in the range {-180,-90,+180,+90} to make sure improper data is not present, then you can reset the envelope of the dataset.
- V
AlisonWieckowicz
VinceAngelo
- V
AlisonWieckowicz
NAILED IT!  Thanks Vince.  You have been helping me via these forums since like 2004!
Here is something that I am still hung up on.....   maybe you could comment.
Why do the records below show up in the right spot on the map?  Every thing appears to be in SRID 26915 so those very lat/long coordinates shouldn’t work right?….
OBJECTID
SHAPE
132150
SDO_GEOMETRY(4402,26915,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,2,1,NULL,NULL,NULL,NULL
,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL
,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL),MDSYS.SDO_ORD
INATE_ARRAY(-93.1870999997482,45.0968999993056,0,-2.73430487141013E-8,-93.187699
9996603,45.1002999991179,0,2.20959191210568E-6,-93.1875,45.1052999999374,0,5.378
57704330236E-6,-93.1858000000939,45.1081000007689,0,7.49122409615666E-6,NULL,NUL
L,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NUL
L,NULL,NULL))
132151
OBJECTID
SHAPE
L,NULL,NULL))
2 rows selected.
VinceAngelo
If CAD objects are involved, Pro will render the CAD objects, not the geometry out of the database. It would be quite odd to get there, but that's the only reason that makes sense.
- V
AlisonWieckowicz
Ok.  I dont believe there is any CAD data.  SE_ANNO_CAD_DATA is null.   Everything is defined as 26915.
VinceAngelo
Can you query the rows in a DA SearchCursor and output the Geometry.WKT for each?  Does that display the correct projected values?
I have no idea how the layer could project on the fly to correct units if it didn't have correct SRID metadata.
- V
AlisonWieckowicz
Now I see that I mistakenly thought that they show up in the correct location.  Some of the bad records are technically multipart features where one part is correct.  This confused me in ArcPro.
Not sure how these were created but at some point someone created the records in the correct location only with the lat/long coordinates.   Then later they appear to have tried to correct them but instead created multipart features where the first part has the erroneous lat/long and the second part has correct utm coordinates.  They are all overlapping.
For example:
SHAPE
SDO_GEOMETRY(4406,26915,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,2,1,17,2,1,NULL,NULL,NU
LL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NU
LL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL),MDSYS.SDO_ORDINATE_AR
RAY(-93.1870999997482,45.0968999993056,0,NULL,-93.1876999996603,45.1002999991179
,0,NULL,-93.1875,45.1052999999374,0,NULL,-93.1858000000939,45.1081000007689,0,NU
LL,485335.1694,4993557.3813,0,NULL,485333.3085,4993569.3357,0,NULL,485334.5785,4
993578.0669,0,NULL,485336.9598,4993586.4807,0,NULL,485338.8648,4993597.9107,0,NU
LL,485341.0873,4993608.7058,0,NULL,485342.6748,4993619.6595,0,NULL,485343.3098,4
993632.3596,0,NULL,485341.4048,4993645.0596,0,NULL,485338.5473,4993657.2834,0,NU
LL,485334.1023,4993670.4596,0,NULL,485329.3398,4993681.0959,0,NULL,485320.1323,4
993694.5897,0,NULL,485312.036,4993704.2734,0,NULL,485304.0985,4993713.1635,0,NUL
L,485293.9385,4993725.546,0,NULL,485287.5884,4993731.896,0,NULL,485280.0566,4993
734.851,0,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL))
VinceAngelo
That makes more sense. You should be able to use SQL to update the lat/lon geometry component, if you just isolate the lat/lon coords and project them.
- V
