Accessing Snowflake with SSO
8892
12
10-12-2022 03:52 AM
SBark_CBRE
I am trying to create a database connection in ArcGIS Pro to Snowflake using SSO. I have successfully created an OLE DB connection to view my tables, but I'm unable to view their spatial component.
The solution would be to create a database connection and then a query layer, but within the settings to create a db connection under 'Authentication Type' it is only possible to select 'User' - which requires a username and login (not possible via SSO).
This is confirmed on Esri's help page - "Only user authentication is supported when you connect to Snowflake from ArcGIS."
Is there a possible workaround to accessing my snowflake data through the database connection option? If not, how can I view the spatial component of my tables that have geography fields?
Info: ArcGIS Pro (v3.0), Enterprise (10.9.1)
RClavero
If anyone else is following up on this, below some recent news shared on a different thread:
https://community.esri.com/t5/data-pipelines-questions/connect-data-pipelines-to-snowflake-via-sso/m... (Thanks @BethanyScott).
NanaDei
Thanks @RClavero . Yes, work is underway to extend support for additional authentication options, starting with key-pair authentication this year. Please create ideas for other authentication options with any specific security policies, if you are looking to use it in ArcGIS Pro and ArcGIS Enterprise.
RClavero
For everyone in this thread, I have just got informed thorugh ENH-000173235 that key pair authentication will be supported in ArcGIS Enterprise 11.5 and ArcGIS Pro 3.5.
