Tracking and Traceability 2026 - Scripts
1714
10-17-2024 12:11 PM
This zip file contains the arcade scripts to enhance Field Maps for ArcGIS with the following capabilities:
  • A sample geodatabase compatible with UPDM 2021. This sample schema has been modified to address the specific needs of mobile as-builting.
  • Arcade calculation expressions to automatically decode the ASTM F2897 barcodes when scanned by a mobile devices camera or Bluetooth scanner.  These scripts work in both a network connected and a network disconnected mode.
  • Incorporates modifications made to the ASTM F2897-23a standard in late 2023. This includes new manufacture components, material types, and pipe dimensions.
  • Automatically capture the original GPS data and write to feature attributes (GPSX, GPSY, GPSZ).
  • Arcade pop-up expressions perform real-time validation of the collected pipe and pipe component information.  Validation checks include:
                 -Verify medium density and high density polyethylene components have not exceeded industry recommended shelf life.
                 -Verify the pipe or pipe component manufacturer is a gas organization approved manufacturer.
                 -Verify the pipe type and size are compliant with gas organization codes and standards.
And more…
Thank you
Tom DeWitte
Esri Technical Lead – Natural Gas Industry
Version history
Last update:
‎06-11-2026 11:46 AM
Updated by:
Contributors
