How do you remove the forest canopy from a Phodar DEM to get bare earth?
2349
06-14-2017 02:20 PM
Labels (3)
by Anonymous User
Not applicable
I'm trying to create a bare earth DEM from Phodar data to create a detailed contour layer. Is there a way to smooth or remove the high points of the canopy?
IanMurray
Honored Contributor
Are the points classified at all?
XanderBakker
Esri Esteemed Contributor
I saw a nice presentation on Improved Vegetation Management with PhoDAR by Dave Twichell, BBaldwin-esristaff  and David Shear which you can find here: http://www.esri.com/events/transmission-summit/~/media/A36CC282BBCA42ABB06F527A648DF5E6
In this presentation there is a comparison between PhoDAR and LiDAR:
Since PhoDAR does not penetrate canopy you will not have any information on the bare earth elevation for areas with dense vegetation. Although in the same presentation the vegetation was classified and one could extract those areas that have no vegetation from your DSM, but you will have to fill up those wholes that are left. In case of large vegetation areas, it will be very difficult to derive a good DEM/DTM from your PhoDAR data.
