ETL from Local Well Known Files
468
05-24-2024 07:32 AM
In an earlier post I enumerated common data source types that you will encounter when bringing data into ArcGIS.  This document discusses one of these data patterns - common file types available on your computer or by simple manual download.
The particular scenario discussed in the attached document is a CSV file with commonly found ETL requirements:  Controlling the output geodatabase feature class schema and creating geometry from a column.  ModelBuilder in ArcGIS Pro 3.3 is the automation environment - it has everything you need, and preserves work for on-demand re-use.
The post attachment includes the discussion document and Model, but not the subject data, which you can download yourself.
Please use this post to ask questions or comment.
Version history
Last update:
‎05-24-2024 07:32 AM
Updated by:
Contributors
