Super newby here
1438
08-07-2024 09:44 AM
AnnMcKnight
Good morning, I need a little guidance. I have been taking the tutorials on my own for a few months now and I have a couple of files I can practice with. But, of course without practice, I can only retain so much. How would you guide me to get started? I have not had any other experience with this other this. Maybe you can guide me to the tutorial that would take me to when I need to sit down and pull data into a map and look at it.
Thank you in advance.
HeatherSmith
Esri Alum
Hello @AnnMcKnight ,
Have you tried this tutorial series? It is a great place to get started with GIS: https://learn.arcgis.com/en/paths/essential-arcgis-online-skills/
If you want to use ArcGIS Pro instead, I recommend this tutorial: https://learn.arcgis.com/en/projects/get-started-with-arcgis-pro/#
If you're looking for data to use, this tutorial will show you how to access and use data from ArcGIS Living Atlas: https://learn.arcgis.com/en/projects/get-started-with-arcgis-living-atlas-of-the-world/
If you're already working with your own data, these short tutorials can help you learn some common skills: https://learn.arcgis.com/en/paths/common-skills-for-working-with-data-arcgis-online/ and https://learn.arcgis.com/en/paths/common-skills-for-working-with-data-in-arcgis-pro/
HeatherSmith
Esri Alum
