Problem With Associations and Utility Networks
1225
12-23-2024 10:09 AM
ZubairHameed
I have been working on the tutorial Try ArcGIS Utility Network.  I am currently having trouble with the section Work with Associations.  I am on the step where I have to use the Add features button from Modify Associations to populate the Active Item menu with the connection point feature by clicking on it.  However, nothing happens when I click on it.  What do you recommend?
HeatherSmith
Esri Alum
Hello @ZubairHameed, I'm sorry to hear about this problem!
I ran through the tutorial steps this morning and did not have the problem you describe. Are you sure that you clicked the Add features button before you clicked the connection point? If the Selection tool is active instead of the Add features tool, the Active item menu will not populate.
