How to filter out raster values and average overlapping buffer values
6544
11-09-2020 03:52 PM
ZiyueXian
I am currently dealing with a raster data with negative values but I want to remove them (aka I only want to keep values >=0). After that I need to map a csv file including thousands of poitns with longtitude/latitude information onto the raster data, and then I need to do a buffer of each point (buffer distance 2.5km). The buffer areas of each point will be overlapping since those points are really close to each other. The final result I want is to have a average buffer value corresponding to each data point, and then export them into a datafile (csv, etc.).
Any help is appreciated regarding removing negative values in raster data & averaging overlapping buffer values and exporting the data.
Thanks ahead!
DavidPike
MVP Notable Contributor
Relassify the raster:
Understanding reclassification—ArcGIS Pro | Documentation
Add xy data (turn the csv to feature points)
Add x,y coordinate data as a layer—ArcGIS Pro | Documentation
Buffer the points by 2.5km:
Buffer (Analysis)—ArcGIS Pro | Documentation
Zonal stats (get stats from underlying raster where intersects each buffer 'zone'):
Zonal Statistics (Spatial Analyst)—ArcGIS Pro | Documentation
