ArcMap had an internal help option. Is this not available in ArcGIS Pro?
1001
03-20-2020 07:10 AM
JosephStocking
Where do I go for simply "how to" questions for ArcGIS Pro?  I used to be able to click on help within ArcMap but I don't see that option in ArcGIS Pro.
DanPatterson_Retired
About ArcGIS Pro Help—ArcGIS Pro | Documentation
check to see if you are using online or downloaded help
JonahLay
Hi Joseph,
You can click on the ? icon in the upper right hand corner of the ArcGIS Pro application to open up the help pages. Installed help (offline) or web help (online) will open depending on your General settings under Option.
Cheers,
Jonah
