arcgis not connected
1203
04-01-2020 03:45 AM
JackDong
I cannot add basemap and the global shows ArcGIS not connected. I cannot solve it according to https://community.esri.com/groups/technical-support/blog/2013/04/01/having-issues-adding-arcgis-onli...
DanPatterson_Retired
can you login to your esri account?
The link doesn't work, it is appearing as text only.
GeoJosh
Hey Jack,
It sounds like you're not connected to an active Portal/ArcGIS Online organization. Try launching ArcGIS Administrator on your machine and check the Portal connections.
Use ArcGIS Desktop with your portal—Portal for ArcGIS (10.5.x) | Documentation for ArcGIS Enterprise
-Josh
