Problem with: Suitability Modeling: Creating a Weighted Suitability Model
2278
01-17-2021 08:45 AM
Labels (2)
PaulWilliamson
Trying to use the Suitability Modeling: Creating a Weighted Suitability Model.
I am using 2.7 ArcPro, rather than Arc Pro 2.6. however, its not been a problem in the past.
When I Browse to C:\EsriTraining\SuitabilityCreateWSM and select the WSM_BaldEagleHabitats project.
The project opens but only with Habitat Analysis: Topography. The other data doesnt load, and I cant upload the geodatabases manually either. When I do I just get:
"failed to add a new file geodatabase" "create new file geodatabase failed"
Any ideas why this is happening? I am used to ArcMap and training to get used to ArcPro, but I have no clue why this is happening. I have opened the geodatabases in ArcMap, and exported the data into a new Geodatabase, but I get the same error.
thanks
PaulWilliamson
Well, discovered the Suitability Modelling issue was due to licensing, sorted now.
Not sure if everything is working but Spatial Analyst was enabled for ArcMap Extension but not ArcPro.
PaulWilliamson
Suzanne-Boden
Glad you got it sorted, Paul. Licensing check boxes can be tricky. 🙂
