Integrating Data in ArcGIS Pro Quiz question
1475
10-23-2020 07:53 AM
MelindaMuzzey
the learning course Integrating Data in ArcGIS Pro has a quiz question that seems wrong but I wanted to get some feedback assuming I just don't understand the question?
The question posted is: Sally wants to import a subset of features from a shapefile into a file geodatabase. Which methods can she use to import a subset of features? (Choose two.)
Options Provided:
  • Export a selection of features from the Contents pane.
  • Copy and paste the shapefile from the Catalog pane.
  • Run the Feature Class To Feature Class tool.
  • Run the Create Feature Class tool.
Based on everything I read the answer should be: Export a selection of features from the Contents pane. AND Run the Feature Class To Feature Class tool. However, the correct answers (based on the quiz) are Export a selection of features from the Contents pane. AND Run the Create Feature Class tool.
I  don't understand why it's Run the Create Feature Class tool since you can't even select a shapefile. Can someone explain? I'm studying to take the entry exam so I want to make sure I understand it.
