Creating Python Scripts for ArcGIS Class Resources
9180
6
01-04-2021 11:16 AM
This 3-day course teaches how to access the Python environment in ArcGIS Pro, script common data management tasks, and automate geoprocessing workflows. You'll learn techniques to share your scripts so they are easily accessible both inside and outside ArcGIS Pro. These resources are dynamic and will be updated as needed.
Resources
Lesson 1 - Introduction to Python and ArcGIS
Lesson 2 - Using Python to access geoprocessing tools
Lesson 3 - Accessing data properties in Python
Lesson 4 - Automating Python scripts with lists
Lesson 5 - Working with cursors
A new data access module (arcpy.da) was added in ArcGIS 10.1. The previously existing cursors (that are still listed under arcpy) are still functional and valid; however, the new arcpy.da cursors include significantly faster performance. In most cases, the help will illustrate the use of the arcpy.da cursors.
Lesson 6 - Working with Geometry objects
Lesson 7 - Using ArcGIS Notebooks
Lesson 8 - Creating a Python Script tool
Lesson 9 - Adding Validation to Script tools
Lesson 10 - Working with Python environments in ArcGIS Pro
Lesson 11 - Using Python script tools in ArcGIS
Extra resources
Tags (1)
Comments
simoxu
by MVP Alum
Good stuff! Thanks.
TommyBrown1
Does this course primarily focus on arcpy or using the ArcGIS API for Python?
JeffBigos
Hi Tommy,
It is a 3 Day course that focuses on arcpy and arcpy workflows.
The ArcGIS API for Python is not covered in this class.
Thanks for the question.
Jeff
by Anonymous User
Not applicable
Wonderfull and congragulations, thank You very much.
Srinivasa_MurthyNemani
Is there a way to get the training data? for the course for later use.
BrittneyWhite1
@Srinivasa_MurthyNemani When you register for the class, you will be given access to the exercise data and workbook on the My Schedule page (https://www.esri.com/training/my-schedule/) three business days prior to the class start date. If you've already taken the class and your link to the course materials has expired, you can reach out to your instructor to request access to the data.
Version history
Last update:
‎08-16-2024 01:23 PM
Updated by:
