Arcgis 19-001 associate exam
1313
05-27-2020 06:41 AM
walidmessaoudi
What about of the new esri exam arcgis descktop associate 19-001 ? I need information about this exam an what is the difference bitween it and the exam associate 10.5 Thanks
Tags (1)
Katie_Clark
MVP Regular Contributor
Hi Walid,
I took the 19-001 Desktop Associate exam in August 2019. The main difference between that exam and 10.5 is that the 19-001 version focuses exclusively on ArcGIS Pro and ArcGIS Online, where the 10.5 version also includes questions about ArcMap. Also, the 19-001 version is not version specific, compared to the 10.5 exam which, obviously, would be more specifically catered to ArcMap 10.5. I was told by Esri that the non-versioned exams are refreshed on an 18-24 month basis.
I chose the 19-001 version since it seemed to align more closely with industry trends, since Esri is in the process of retiring ArcMap. But there's obviously no "right" answer here.
To study, I took all of the free courses in the Esri learning plan for this exam, as well as reviewed the exam guide to see if there were any knowledge gaps I needed to brush up on (for instance, I had no prior experience working with 3D data). That, in combination with my on-the-job experience, worked well enough for me that I passed the exam. There are certainly enough resources out there that you shouldn't need to spend a lot of money to prepare for the exam, in my opinion.
Hope that helps!
Katherine
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
