ESDP 2025 EIG
4567
03-13-2025 11:12 AM
JenniferParra
ArcGIS Enterprise System Design Professional 2025 Exam Information Guide
Click here to return to the Esri Academy description page for this exam.
Exam Details
  • Exam Questions: 75
  • Exam Duration: 1 Hour, 45 Minutes
  • Exam Format: Multiple Choice
  • Exam Language: English
  • Certification Code: ESDP_2025
  • Exam State: Available to Public
    • Published Date: 13 November 2025
    • Visit Esri Community to learn more about this exam
Exam Purpose
The ArcGIS Enterprise System Design Professional 2025 exam tests the candidate’s ability to design an advanced ArcGIS Enterprise system for clients that may include custom solutions for unique projects and use cases using best practices. It expects the candidate to have at least 4 years of applied experience with ArcGIS Enterprise system design.
Target Candidate Audience
The ArcGIS Enterprise System Design Professional 2025 exam is intended for IT and GIS professionals with experience in GIS architecture and designing enterprise systems. Roles may include but are not limited to: GIS administrators, GIS managers, GIS consultants, and Enterprise architects.
Description of Qualified Candidate
The ArcGIS Enterprise System Design Professional 2025 exam is designed for candidates with a mid to high level of diverse and varied experience in enterprise system design and implementation. Candidates should have at least 4 years of applied experience with ArcGIS Enterprise system design.
These candidates should have knowledge of the components of an enterprise solution and perform advanced troubleshooting of enterprise systems. Qualified candidates should be proficient in best practices related to architecture design and capacity planning.
Candidate Qualifications
A qualified candidate should be able to perform the following tasks:
  • Design solution, application, data, security and system architecture
  • Translate functional and nonfunctional requirements into solution and system design
  • Design an ArcGIS Enterprise system for high availability and disaster recovery
  • Determine the correct security mechanisms for authentication and authorization and the right security posture for the system
  • Calculate system capacity
  • Determine licensing requirements
  • Define infrastructure components configuration (for example, Load Balancer, Networking)
  • Design system integrations on apps, services, and data levels
  • Identify and troubleshoot infrastructure issues
  • Design a disaster recovery strategy
  • Design architectures for cloud and virtualized environments
  • Design virtual desktop infrastructure for clients
The following tasks are considered beyond the knowledge, skills, and abilities of the qualified candidate:
  • Advise on complex security architecture patterns
  • Understand complex Load Balancer configurations
  • Understand complex networking
A qualified candidate should be familiar with the following:
  • ArcGIS Enterprise 11.4
  • ArcGIS Monitor 2024.x
  • GIS Enterprise Reporter
  • System Log Parser
  • eGDB Health
  • Network tracing tools (for example, Fiddler, DevTools)
  • Infrastructure troubleshooting tools (for example, Process Monitor, Sysmon)
  • Command-line shells (for example, CMD, PowerShell, Shell)
Skills Measured
Candidates should use the exam content sections below as a checklist to identify gaps between their knowledge and the skills measured by the exam. The relative weight indicates the approximate size of each section. It is recommended that preparation be focused in areas where knowledge gaps are found.
Physical Architecture 35%
  • Apply procedural concepts to document physical architecture that will meet nonfunctional requirements
  • Design a highly available deployment
  • Identify the URLs used in ArcGIS Enterprise
  • Given a scenario, use system design inputs to calculate required server capacities
  • Apply procedural concepts to adjust architecture to meet requirements and constraints
  • Given a scenario, determine which VDI configuration to use
Solution Architecture 26%
  • Identify ArcGIS components that will be required in the design
  • Identify ArcGIS Server roles/extensions that will be required in the design
  • Identify appropriate Data Store types
  • Given a scenario, determine authentication methods based on business needs
  • Adjust architectural solution to meet constraints
Deployment and Troubleshooting 14%
  • Apply procedural concepts to select an upgrade strategy
  • Identify potential system integration issues
  • Interpret results and data from tools
  • Determine which ArcGIS Monitor component to use
Architectural Concepts 25%
  • Determine when to use workload separation
  • Design system based on environment isolation needs
  • Determine which type of collaboration to use based on requirements
  • Apply procedural concepts to identify a content delivery strategy
  • Identify methods for backup, replication and/or resiliency
  • Given a scenario, determine when to use tiered architectures
Resources
To help prepare for the exam, we recommend candidates use the training resources provided below, along with reviewing the list of exam objectives, to identify and fill any knowledge gaps. Completing the recommended training courses does not guarantee a passing score on a certification exam.
The Esri-curated learning plan for this exam is updated regularly to reflect the latest Esri Academy resources and resource retirement schedules.
Esri Academy
Esri Community
Link to ArcGIS Documentation
This exam is still in development, but check out these version resources below:
Stay Connected
We hope you will subscribe to this article to keep up to date with the progress of this exam update and click this link to Ask Questions.
Contributors
About the Author
I am a Sr Global Training Specialist within Esri Training Services. I support exam development for the Technical Certification Program.
