Dynamic Choropleth map with filtering
669
08-22-2025 11:47 AM
adimuro1
I have two layers in my ARCGIS Pro map. One has polygon geometry with divisions (about 30 rows), and the other is point geometry for incident data (date, time, incident number, etc. Which eventually could have over 100,000 rows). Using spatial join I have created a choropleth map with graduated symbology indicating which divisions have the highest incident count. However the issue is that the attribute table associated with this map condenses to only the 30 rows, but I think I will need row per incident data for detailed filtering. I want to keep this choropleth symbology for my end result, but would like the map to be more dynamic so users can filter for certain dates, incident numbers, etc and the map will adjust the visuals (colors and labels) for that selected filter. I do have lat long data for my incidents, however I do not want the end user to be able to see the specific lat longs. Ideally the map would be displayed in a PowerBI dashboard, but please let me know if other platforms would work better such as storymaps, etc.
Any help on how to dynamically display incident data at the divisional level allowing for filtering would be greatly appreciated!
DavidPike
MVP Notable Contributor
These seems like a use case for a Dashboard or Experience Builder.  Do you have access to these?
