Getting Started with the ArcGIS API for JavaScript
2690
08-18-2016 03:48 AM
MichaelKelly
The ArcGIS API for JavaScript is designed to maximise your productivity for building engaging, beautiful web mapping applications. The API combines modern web technology and powerful geospatial capabilities enabling you to create high-performing apps and smarter visualisations of your data. In this webinar, Michael Kelly (Technical Sales Engineer) of Esri Ireland will highlight some key aspects of the API, and recommend related resources.
Schedule
  • ArcGIS Online Overview - may save you coding!
  • Configuration of Applications
  • Using the ArcGIS API for JavaScript documentation
  • ArcGIS API for JavaScript basics
  • Walk through of sample JavaScript application code
Audience
  • Users interested in learning more about the ArcGIS API for JavaScript
Prerequisites
  • Basic knowledge of the ArcGIS Platform
  • Basic JavaScript knowledge
MichaelKelly
Webinar Q&A
Where can we download the presentation?
The presentation is now available from this link.
Which IDE is this?
The IDE I use is called Brackets.
Could you provide links to tutorials in relation to developing apps with ArcGIS API code?
Absolutely - here are two links (here and here) that should get you up and running. There is also lots of sample code available here.
Is there any licence option between 5 user licence and 50 user licence yet?
Currently named user licences only come in packs of 5 or 50 for ArcGIS Online. However, you can purchase 2 x 5 named user licences if necessary.
3D support in JS by ESRI, wherein we can create web apps from 3D Scene services also even on Mobile device using webGL or similar technology.
This is something that is being worked on with the 4.x version of the ArcGIS API for JavaScript API.
Coding in relation to widgets for ArcGIS Online apps.
I assume you are speaking about Web AppBuilder widgets. There are some very good videos relating to customising and extending Web AppBuilder for ArcGIS widgets available from this link. We will consider this topic for a future webinar.
