restoring the backup file few layers are missing on PostgreSQL database
876
07-16-2018 09:46 PM
pradeepkanth
Can you please help me, While restoring the backup file few layers are missing on PostgreSQL database.
I have followed the below steps and let us know how to overcome this issue.
Followed Process:
  1. Create a backup with individual schema and also tried with full database backup
  2. Created a new database with same name like source database and executed alter database sde set search_path = E'\$user',public,sde; on target database.
  3. Give the same permission on Target database same as source database.
  4. Copied the Library files into Target database.
  5. Restore the contents of the public after that sde schema.
  6. Restore the entire database for all schemas(Except public & sde schema)
  7. While restoring the backup file, we are getting the below yellow highlighted error messages.
pg_restore: [archiver (db)] COPY failed for table "******": ERROR:  Invalid geometry
HINT: 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error in parsing the source string
CONTEXT:  COPY *****, line 683, column shape: "000200005000000004000C00E6100000A807000001000000B3969A98FA1B84C4F7EADE17E0AF02C08650EA36EDB40ECFC60E..."
Note: While copying the feature classes through ArcCatalog from source to target database, we have not seen any errors.
Software’s: ArcGIS 10.6
Database : PostgreSQL 9.5.3 with PostGIS 2.3.0
