Issue in Mosaicing Raster data set
2493
08-03-2016 07:25 AM
SandipSawant
Dear Experts,
I am facing issue while using ESRI Tool => Add Raster to Mosaic dataset.
Here I have two different dataset of Raster to which I want to merge into single data set by keeping to color symbology different for 2 attribute data after merging. Accordingly I have 2 different "Value" i.e. 1 & 2 for the both the raster dataset (I checked this in Arccatalog - preview attribute panel. Also we have .clr file present in the path where output raster is getting created.
However after merging raster dataset I am getting only one colored single raster dataset. So seems like either one data set is getting either excluded while merging or some parameter is configured correctly to get the right thing. Please refer data attached image where 2 different raster data set are shown which are inputs I am using to mosaic.
Kindly suggest in case any solution/any option missing in mosaic/any bugs in toolbox here...
Thanks in advance!
Sandip
DanPatterson_Retired
you would be advised to move this to Imagery and Remote Sensing​ to expedite an answer,  India doesn't get much traffic
JayantaPoddar
Instead of Mosaicking, I would recommend you use Raster Calculator to accomplish the task using conditional statement.
Con(("Data1"==0), "Data2", "Data1")
Think Location
SandipSawant
I managed to solve this by work around of using “Mosaic to new raster“ tool where we can give MATCH option, can keep .CLR file (Color remap file) in same folder where we are generating output file.
And for miscellaneous issue can reverse the sequence of input raster’s (which I had to) and generate the required image file.
- Sandip
