Using GIS for Site Selection in Semiconductor Fab Development, thoughts?,
180
5
3 weeks ago
ShareUser
Esri Community Manager
I've been thinking about this a lot lately, and I wanted to throw it out to the community because I know a lot of you work on industrial and infrastructure siting.
Semiconductor fabs are one of the most unforgiving building types out there when it comes to site selection. We're not just looking for flat land near a highway anymore. A modern fab needs massive, stable power (we're talking hundreds of megawatts), millions of gallons of ultrapure water a day, seismic stability down to fractions of a millimeter of vibration tolerance, and proximity to a labor pool with very specific technical skills. Get any one of those wrong and you're looking at billions in stranded investment.
Here's where I think GIS stops being a "nice to have" and becomes the only real way to do this seriously. You can't evaluate that many overlapping constraints in a spreadsheet. You need to be able to layer utility infrastructure maps against floodplain data, seismic hazard zones, water rights and aquifer recharge data, transmission line capacity, rail and highway access, and workforce demographics, all at once, across multiple candidate regions — and actually see where the viable envelope is.
What I find most interesting is the water piece. Everyone talks about power availability, but ultrapure water sourcing and wastewater discharge permitting can quietly kill a site faster than power ever will. Overlaying watershed boundaries, existing water rights allocations, and drought risk models onto candidate sites tends to surface problems way earlier than a traditional feasibility study would.
The other thing I keep coming back to is incentive-zone overlap. A lot of states are stacking opportunity zones, foreign trade zones, and CHIPS Act-adjacent incentive districts on top of each other right now. If your GIS analysis isn't tracking those boundaries alongside the physical constraints, you might rule out a site that's actually financially the strongest option once incentives are factored in, or vice versa.
Where I'd push back on myself a little: GIS is incredible at narrowing the field, but it can create a false sense of precision. A weighted suitability model is only as good as the weights you assign to power vs. water vs. seismic vs. workforce, and those weights are ultimately a judgment call, not a purely data-driven output. I've seen teams treat a suitability score like it's gospel when it's really just a structured way of organizing an opinion.
Curious how others here are approaching the multi-criteria weighting side of this. Are you leaning on AHP (analytic hierarchy process) to defend your weighting choices to stakeholders, or something looser? And is anyone incorporating grid interconnection queue data into their models yet, given how long some regions are taking to approve new industrial-scale power draws?
Would love to hear how other GIS folks are tackling fab siting, especially anyone who's worked a project through to groundbreaking. What did the data get right, and where did it steer you wrong?
ShareUser
This is a great question and conversation starter, @ReetieL. I've shared copies of this post to our Environment Questions, AEC (Architecture, Engineering, and Construction) Questions, and Water Resources Questions boards to increase relevant visibility. Comments will stay synced across the posts via the method I used, so members can comment and respond from any copy.
ShareUser
Thanks so much, @JesseCloutier. I really appreciate you helping expand the conversation across communities. Those perspectives are exactly what I was hoping to bring together, since semiconductor siting touches all three disciplines. If it's not too much trouble, would you mind sharing the links to those posts as well? I'd love to follow the discussions and engage with anyone who joins the conversation. Thanks again!
ShareUser
You're more than welcome. Because of the way I shared the post, comments will sync across each copy. This means that if someone comments on any of the posts, the other copies will update with that comment as well (note that when a comment syncs to other copies, the username will show as ShareUser but there is a source author name listed below it). I just discovered that the system was unable to share a copy to our Water Resources Questions board because of a conflict with label requirements. The other two are here and here. All the best!
ShareUser
Thanks . @JesseCloutier  appreciate that! Good to know about the ShareUser thing so I don't get confused later. Regarding the Water Resources board, is there a label fix I can make on my end so you can try resharing, or is it a config thing on their side?
Thanks again for spreading this around!
ShareUser
It's a fixed feature of the Water Resources Questions board. That doesn't mean you can't start a new post there, though. You can ask a question to prompt a discussion around the water resources aspect of this if you'd like.
