Spatial Join - setting distance
2766
12-14-2016 11:39 AM
TimHayes1
I am using ArcGIS 10.2.2.
I need to join the attributes of a Point Feature Class to a Line Feature Class.
The points are all snapped to the ends of the lines. I want to transfer the attributes from the points to the lines. How is this done?
I tried spatial join as shown below. But, when selecting the "Each line will be given all the attributes of the point that is closest to it..." joins with the pipe the point is snapped too and the nearest pipe. The result is sometimes a point's attributes are transferred to more than one line. I only want to join the attributes from points that are snapped to the line to the line the point is snapped to; One Point = One Line.
JayantaPoddar
MVP Alum
You might like to use Spatial Join Geoprocessing tool (Match Option = INTERSECT).
Think Location
JayantaPoddar
MVP Alum
Think Location
