Spatial index grid size is valid in updating subnetwork
1537
06-12-2023 05:00 AM
RomuldKiobya
I have read different articles from Esri but not working. I face this challenge mentioned above. I have tried to delete and create a new spatial index on the feature class. But nothing change. Attached doc below
JohnAlsup
First, you should report this issue to Esri support.   They will need full details and more than likely a copy of your database.
If you have two tiers in your network, Transmission and Distribution, and you enable the topology and then run update subnetwork in the distribution tier first, then try to run update in the Transmission tier on a subnetwork, you could encounter this error.  You could also encounter in the same tier if the first subnetwork processed has a very small extent.  You should try starting with running update subnetwork with the subnetwork that probably has the largest extent.
But again, please submit an issue to Esri support.
John Alsup
[email protected]
GIS_Solutions
Hi @RomuldKiobya
You should delete the spatial index in the subnetline feature class. Then you can run the update subnetwork tool. it will not give an error. When you see that it doesn't give an error, you can recreate the spatial index.
