Calculating Deflection Angles for Transmission Line Routes
4630
12-06-2023 11:52 AM
BrianBerube_GIS
Hi All,
I've done some work this year with transmission routing and scoring for new projects. This work was done based on a request to determine the design deflection angle for a series of proposed structure locations along a new transmission route.
Based on this specific request and need, I created a python script that takes the input of any polyline (planned transmission project route), creates points at the vertices of that polyline, and calculates the relative deflection angle at each location. The output is a point feature class written out to the input workspace that  contains attribute information that can be used to benefit scoring criteria for cost considerations when planning new projects.
1.)What use cases would this group find beneficial around this type of tool and output in any planning workflows you have which involve routing and scoring?
2.) What are you all doing to support workflows involving the ever increasing number of projects within your organization and how you are using GIS to help meet your organizational needs now and going forward?
3.) Feel free to copy and paste the python below into your ArcGIS Pro Project and try it out. Any questions or comments please reply to the group to get this conversation going.
import arcpy
import math
import os
# Define the input polyline feature class
line_fc = r""
# Define the output point feature class
filename = os.path.basename(line_fc)
output_fc = "deflection_angles_points_" + filename
# Create the output point feature class with the required fields
arcpy.CreateFeatureclass_management(
arcpy.env.workspace, output_fc, "POINT", line_fc, "SAME_AS_TEMPLATE"
arcpy.AddField_management(output_fc, "Vertex_Order", "LONG")
arcpy.AddField_management(output_fc, "Deflection_Angle", "DOUBLE")
# Iterate through each vertex of the polyline and calculate the deflection angle
with arcpy.da.SearchCursor(line_fc, ["OID@", "SHAPE@"]) as cursor:
with arcpy.da.InsertCursor(output_fc, ["OID@", "SHAPE@", "Vertex_Order", "Deflection_Angle"]) as insert_cursor:
for row in cursor:
object_id = row[0]
polyline = row[1]
# Iterate through each part of the polyline
for part_index in range(polyline.partCount):
part = polyline.getPart(part_index)
# Iterate through each vertex in the current part
for vertex_index in range(len(part)):
vertex = part[vertex_index]
# Calculate the deflection angle for the current vertex
if vertex_index > 0 and vertex_index < len(part) - 1:
previous_vertex = part[vertex_index - 1]
next_vertex = part[vertex_index + 1]
x1, y1 = previous_vertex.X, previous_vertex.Y
x2, y2 = vertex.X, vertex.Y
x3, y3 = next_vertex.X, next_vertex.Y
angle_rad = math.atan2(y3 - y2, x3 - x2) - math.atan2(y1 - y2, x1 - x2)
angle_deg = abs(math.degrees(angle_rad))
# Adjust the angle to be within the range of 0-90 degrees for each quadrant
if angle_deg < 0:
angle_deg += abs(360)
if angle_deg > 90:
angle_deg = abs(180 - angle_deg)
# Create a new point feature with the calculated deflection angle
point = arcpy.Point(vertex.X, vertex.Y)
point_geometry = arcpy.PointGeometry(point, polyline.spatialReference)
insert_cursor.insertRow([object_id, point_geometry, vertex_index, angle_deg])
# Print a message when the script is completed
print("Deflection angles calculated and stored in the output feature class.")
BrianBerube_GIS
@JasonBrekke do you have any discussion points around this? I know last we discussed this was certainly something you all were working on...
JasonBrekke
@BrianBerube_GIS , this tool has worked great for us as we look to objectively score transmission route options within a project area.  We can apply a cost to the structure and foundation using these values.  Other criteria used include total line length, land use within ROW (cropland vs. pasture), number and type of pipeline crossings, number and voltage of transmission line crossings, length and number of contiguous fields bisected, conservation easements crossed, and currently, we are looking to incorporate slope to the model as that can affect the cost of construction.  At Basin Electric, we would love to hear if others are doing anything similar.  Thanks again @BrianBerube_GIS for creating this tool.
BillMeehan
Thanks, Jason, for your contribution. I'd love to do a story on your success using this tool or, in general, your work on siting and land use.
Pat_Hohl
very cool !
BillMeehan
Thanks, Brian. This is a very important factor in the determination of the cost of a transmission line. Changes in direction require special structures that can significantly add to the cost of transmission lines.
