suppress certificate warning
705
12-11-2019 10:38 AM
Status: Open
forestknutsen1
The certificate popup window warnings are a real-time suck for me in dev environments that don't have proper certificates when calling arcpy.CreateGeocodeSDDraft. Can a parameter be added to the arcpy server calls to suppress the warning? This problem makes arcpy useless in some situations.
print "Create sddraft"
analyze_message = arcpy.CreateGeocodeSDDraft(loc_path=loc_path,
                                             out_sddraft=out_sddraft,
                                             service_name=service_name,
                                             server_type=server_type,
                                             connection_file_path=connection_file_path,
                                             copy_data_to_server=copy_data_to_server,
                                             supported_operations=supported_operations,
                                             folder_name=folder_name)
Tags (3)
