RCE eyedropper tool copies populated event data only
909
12-08-2014 07:09 PM
Status: Open
BryanKelley
In Roads and Highways - Roadway Characteristic Editor, when using the eyedropper tool to copy attributes from one record to another in RCE, it would be useful if there was a toggle switch to let the user either copy all attribute values or only the ones that are populated.  The way the tool functions now is that records will be created with null values where there are nulls in the existing record.  The toggle should cause the software to realize the attribute was null and not present the attributes in the first place on the copies record.  Otherwise, the user has to uncheck all the blank options so as not to create null records. This is in 10.2.2 patch 1.
