Data grouping in ArcObjects
1039
01-28-2017 09:01 PM
Status: Open
MaxMax2
There are no built-in methods in ArcObjects to perform grouping of rows/features. It is common task in table processing so it is strange to me that this functionality is missed. To implement grouping developers can use at now following approaches:
IQueryFilterDefinition.PostfixClause
IQueryFilter queryFilter = new QueryFilterClass
    PostfixClause = "GROUP BY SOME_FIELD"
ICursor cursor = table.Search(queryFilter, true);‍‍‍‍‍‍
But:
  1. this works only for GDBs;
  2. you need manually determine where current group ends and starts another one (in other words, you need track changings of field's value while iterating by cursor);
  3. it is unable to perform custom grouping, for example, based on some spatial criteria.
ITableSort
You can sort rows with ITableSort and then iterate through records to form groups. But:
  1. ITableSort has some limitations:
    • it can't be used to sort tables without an ObjectID field;
    • it can't be used to perform custom sorting based on some spatial criteria.
  2. as with first approach you need track changings of field's value while iterating by cursor to determine end of each group.
It would be great if you provide a way to group table data in ArcObjects with following key features:
  1. iterating by groups, so it will be easy to know their bounds;
  2. grouping by multiple fields;
  3. support for shapefiles and tables without an ObjectID field;
  4. ability to use custom grouping logic.
It can be something like that:
public class CustomTableGroup : ITableGroupCallBack
    public bool IsNewGroup(int[] fieldIndicies, object[] currentValues, object[] newValues)
        // determine here if passed newValues start a new group
ITableGroup tableGroup = new TableGroupClass
    Table = table,
    Fields = "field1, field2, field3",
    Group = new CustomTableGroup()
IGroupCursor groupCursor = null;
try
    groupCursor = tableGroup.Group();
    for (IGroup group; (group = groupCursor.NextGroup()) != null;)
        // indices of the fields to group by
        int[] fieldIndices = group.FieldIndices;
        // values of the fields to group by for the current group
        object[] fieldValues = group.FieldValues;
        // iterate through the group
        ICursor cursor = null;
        try
            cursor = group.Rows;
            for (IRow row; (row = cursor.NextRow()) != null;)
                // do something
        finally
            if (cursor != null)
                Marshal.ReleaseComObject(cursor);
finally
    if (groupCursor != null)
        Marshal.ReleaseComObject(groupCursor);
