Arcade Documentation: Arcade FeatureSets / related FCs
1014
03-06-2022 02:32 PM
Status: Open
Bud
Legendary Contributor
The FeatureSets section in Arcade developer documentation seems a bit misleading.
It suggests that a FC needs to be in a map service or feature service in order to use it as a related FC in an Arcade expression:
FeatureSets allow you to access features from feature service layers within the map or feature service.
If I understand correctly, a FC doesn't need to be in a map or feature service in order to use it as a related FC in Arcade:
Arcade: Use related FCs without needing feature service
Could the developer documentation be changed to make the above more obvious?
Thanks!
