Add an option to support grid line width updates
1420
10-29-2025 01:16 PM
Status: Open
Brian_McLeer
MVP Regular Contributor
Allow users to update line widths of grids to Grid Controls. Sometimes grid lines can be hard to see against aerial imagery.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-support-GridControls.html
4 Comments
bbollin
Hi @Brian_McLeer, thanks for the feedback! Will pass on to the team
Noah-Sager
Hi @Brian_McLeer, thanks for posting your idea here. Do the color and theme properties work for your use case? If not, could you explain how a width property would work better?
Brian_McLeer
Hello @Noah-Sager and @bbollin, thank you for the quick response. Updating colors/theme can work in some cases. However in the image below when you have varying symbology on top of a raster basemap, the thinner lines can become muted even though the color is a bright orange. Allowing users to adjust overall thickness of gridlines would allow more contrast against content with high degrees of color. I would like to point the larger gridlines are not hard to see, but the smaller sized grids can be hard to see.
Noah-Sager
Status changed to: Open
