xml error import = cannot create a table with a duplicate column
2215
07-08-2014 11:13 AM
GabiVoicu
i have exported an XML workspace document and saved it outside and now trying to import it back into a brand new geodatabase and gives me this error
"cannot create a table with a duplicate column"
Thank you
Tags (3)
GabiVoicu
Is there anything in ArcGIS that would help us identify which table has a duplicate column?
DonOpgenorth
I've moved your post into the  Managing Data space. You will get a much better answer here as the GeoNet Help is intended for community help and feedback. I have also added in a few additional tags. You can see more on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Don
