Workflow to modify topology in Archived SDE Geodatabase
997
12-09-2010 08:59 AM
MarkVolz
Hello,
I have a SDE geodatabase that has historical archiving enabled.  I would like to modify the topology of one of my feature datasets.  From my understanding topology can be used in versioned / archived geodatabases however, the topology cannot be modified.
The workflow that I have thus far is:
Delete, post any versions
Disable Archiving  (do not delete history tables)
Unregister as versioned
Change Topology
Register as versioned
Enable archiving
The problem that I have is that I lose all of my historical changes.  Is there a way to "load history tables" into the SDE geodatabase, or is there a different workflow to modify topology?
Thanks
