where can I get the sde.st_buffer distance units?
3632
08-22-2014 11:33 AM
WalterEralio
I need to spatial query a layer in WGS84 with a variable amount of FEETs  but cannot seem to find documentation on the units the st_buffer functions is using
Tags (1)
VinceAngelo
Esri Esteemed Contributor
SDE.ST_BUFFER uses Cartesian map units in the coordinate reference of the SRID of the column.  For GCS_WGS_1984, this will be linear degrees.   You can use SDE.ST_TRANSFORM to change the buffer about a PCS feature into a GCS geometry for search.
- V
VinceAngelo
- V
